Re: H STEERING SHAFT U JOINT
Posted by David B on June 07, 2004 at 19:46:03 from (205.240.41.17):
In Reply to: H STEERING SHAFT U JOINT posted by JON on June 07, 2004 at 18:15:34:
If the U-Joint is sloppy around the steering shaft (the one the goes to the front through the radiator), shim it up with some brass shim. Works great. just did it to a '42 H.
Post a Followup
: Re: Re: H STEERING SHAFT U JOINT
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
