Re: M rear end
Posted by RPM on June 11, 2004 at 06:53:35 from (209.152.115.185):
In Reply to: M rear end posted by Roger on June 09, 2004 at 14:40:19:
If you plan on keeping the tractor and using it it needs to have all the axle bearings checked and the brake shafts (bull gear pinions) bearings, these are all ball bearing and they will fail, seen it happen many times, if you dont a loose ball will get into the brake shaft gear teeth and the bull gear, it just makes a mess, I worked at a IH dealer from 1960 till 1992 and this was a common problem.
Post a Followup
: Re: Re: M rear end
