Re: Re: Re: M Governor
Posted by CNKS on June 13, 2004 at 19:43:55 from (207.178.96.214):
In Reply to: Re: Re: M Governor posted by Paul G. in Mn on June 13, 2004 at 18:42:51:
I have not tried to work on the H/M governor, so all I can do is read what is in the service manual: "The bottom screw sets the high idle -- out to increase speed, in to decrease speed." This adjustment is made with the throttle control lever wide open (rear position). With the throttle closed and assuming the carb idle screw is set to about the right rpm, 425 rpm: "The upper screw should be adjusted to just touch it's stop. At this setting the governor spring should be free; it will not be possible to set the low idle speed when the screw is adjusted so there is tension in the spring." "The linkage between the engine speed control lever and the governor speed change lever should be adjusted so that both stop screws will touch their stops at the extremes of the engine speed control lever movement". This is the meat of the description in the manual. If you have had the carb off remember that the carburetor throttle shaft must properly engage the rod that connects the carb to the governor, or nothing will work right.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
