Re: Super A carb dripping
Posted by FC on June 14, 2004 at 05:47:21 from (66.84.205.26):
In Reply to: Super A carb dripping posted by Al Freeberg on June 13, 2004 at 20:12:41:
Is it a Carter UT carb? And does it drip while it is running? The reason I ask is that I have one on my C and it drips after it has been shut down for a while. It will leak the entire tank out if you do not shut down the fuel valve. I finally gave up on it and just shut off the gas at the tank when I am done with it. Dad done this for years on this tractor due to dripping carb, and I thought I could fix it....wrong.
Post a Followup
: Re: Re: Super A carb dripping
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
