Re: Re: Re: Re: Re: Re: Re: M Governor
Posted by rustyfarmall on June 14, 2004 at 08:39:29 from (216.248.75.146):
In Reply to: Re: Re: Re: Re: Re: Re: M Governor posted by Short pull on June 13, 2004 at 19:49:46:
Also, the holes where the spring attaches are probably worn out, you can weld, or braze them shut and then drill new holes. You can even drill in a slightly different location in order to tighten up that spring.
Post a Followup
: Re: Re: Re: Re: Re: Re: Re: Re: M Governor
