Re: M crankshaft
Posted by El Toro on June 14, 2004 at 12:00:29 from (205.188.117.22):
In Reply to: M crankshaft posted by nebraska cowman on June 14, 2004 at 03:15:37:
According to the IH dealer in our area the Farmall M and Super M use the same connecting rods. The rod journal on the Super M is 2.5475-2.5485" and on the M it is 2.4975-2.4985". The mains on the M are 2.7475-2.7485". I thought the
bearings in the Super M may have been wider in width, but if the rods are same number, that isn't true. It should fit using the Super M bearings. The stroke is 5.25" on both tractors.
I was also concerned about the height of the pistons at full travel, but this looks to be alright. Good Luck Hal
Post a Followup
: Re: Re: M crankshaft
