Farmall A Battery Size and Cable Lenghts Needed
Posted by Tim on June 14, 2004 at 16:19:48 from (66.189.46.148):
I am putting a '45 Farmall A back together that had a cobbled up starting system.
Does anyone know what size/group the proper 6 volt battery is? I also need to know the proper lengths for the cables. I know the negative goes to the starter but don't know where the positive ground was originally hooked up...?
Thanks in advance,
Tim
Post a Followup
: Re: Farmall A Battery Size and Cable Lenghts Needed
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
