Re: M rear axle bearings
Posted by Thresherman on June 14, 2004 at 20:18:31 from (66.181.128.26):
In Reply to: M rear axle bearings posted by Roger on June 14, 2004 at 16:02:02:
You might just overfill the trans to get oil to them. I think you might be missing the point. You are concerned about the number of balls, when you should be concerned about the proper lubrication practice. These outer axle bearings require grease. If you look at the end of the axle housing there is a grease zerk that needs to be lubricated quite often. The bearing use the grease for lube, not gear oil.
Just my input.
Post a Followup
: Re: Re: M rear axle bearings
