Could really use a quick answer, 300 Utility.
Posted by Loren on June 14, 2004 at 21:02:01 from (12.108.31.89):
On the transmission driveshaft bearing cage (#65 in I&T manual, housing that holds the planet carrier for the TA) there is what looks to be a drain port for the bearing lube. Mine was pointing up, is this not a drain port that points down? Loren
Post a Followup
: Re: Could really use a quick answer, 300 Utility.
