Re: The M stalled again
Posted by El Toro on June 15, 2004 at 06:13:44 from (205.188.117.22):
In Reply to: The M stalled again posted by William Ransom on June 14, 2004 at 11:24:05:
Hi William, Rustyfarmall's advice is the best,
pull the gas tank and have it steam cleaned. That will remove any dried gas deposits and any dirt. Then rebuild your carb. I had the same problems on a GM car that kept stalling and pinging. Everyone said it was the EGR, that didn't help. I always thought it was a fuel problem. I silver soldered a 1/8 pipe fitting on
the fuel line and hooked up a pressure gauge. The
pressure was fine until you accelerated, then the
pressure dropped. I pulled the tank and removed the pump and vacuumed the tank. It was full of rust and krud. I installed a new pump and sock over the pump inlet. It ran like new car. Hal
Post a Followup
: Re: Re: The M stalled again
