B Farmall
Posted by Deryl on June 15, 2004 at 07:13:51 from (66.14.219.89):
I have a 1947 "B" farmall, I want to mow 10 acres of horse pasture. Would a belly mower work, how wide 4' or 5'. Could use a pull behind bush hog style mower, again should I go with 4' or 5'. Also, someone has recommended using a 3 pt. finish mower, by welding up brackets to bolt to drawbar and letting it run on its own wheels. Has anyone mowed with a "B" farmall; will it handle 5' mower thru thick pasture grass or should I get 4' width. Thanks for any input.
Post a Followup
: Re: B Farmall
