Re: B Farmall
Posted by Dave in Texas on June 15, 2004 at 08:59:36 from (66.134.33.190):
In Reply to: B Farmall posted by Deryl on June 15, 2004 at 07:13:51:
I have a B. I have used it with a 5' pull behind and it does OK. It is more sensitive to the off balance of the mower blades than I like. It is compariable to my Ford 9N. It lugs down in thick grass but pulls through it. Make sure you add the coupler on the PTO shaft. I now use the pull behind on an H. It does better.
I now use the B with a 6' Woods finish mower. This works really good but the grass is not to high. The turning radius is a big plus.
Post a Followup
: Re: Re: B Farmall
