Re: Re: Sand blasting concerns
Posted by CNKS on June 15, 2004 at 19:11:25 from (207.178.96.212):
In Reply to: Re: Sand blasting concerns posted by Brian on June 15, 2004 at 18:56:03:
It depends on what kind of paint job you want. I've seen "painted" tractors where the painter didn't even bother the remove the oil filter, carb, or distributer. The paint (that is, the small amount that actually gets there) goes over dirt and grease behind those items. The only way to get uniform paint on everything is to disassemble it. You can clean it with various combinations of oven cleaner, paint stripper, and pressure washing. Also an angle grinder and/or wire brushes on an electric drill. A good job will take a lot of time. There is no free lunch.
Post a Followup
: Re: Re: Re: Sand blasting concerns
