IH 2 disk breaking plow questions
Posted by John (AZ) on June 16, 2004 at 02:43:59 from (149.174.164.83):
I recently purchased a IH 2 disk plow that is large and heavy but I see no model ID on it just the IHC logo. This plow has an adjustable height tail wheel. The disks and tail wheel are roughly 24" dia. and the tail wheel is adjusted up and down with a handle that is about 3 ft. long, the tail wheel is attached to plow frame by a heavy casting. total plow lenght is about 5-6 Ft.
This plow has a bar at the front to attach to the draw bar on my H but this bar was fabricatedby someone and has one "clevis" in the center to hook to the draw bar.
Now after I got it home and hooked up to the tractor the plow doesn't track properly and keeps tilting to one side or the other.
So now I'm looking better at this plow and decide it must have been a semi mounted plow at some point. But I don't belive all the mounting parts are there.
I know this discription is kind of sketchy at best but does anyone have any idea What plow model it might be so I can find any pictures of what is supposed to be there to mount this to tractor.
I'm thinking this plow would have to have something to lift the plow clear of the ground so you can turn the tractor. I can do this with the tail wheel but I have to dismount the tractor to raise the plow and the tail wheel is designed not to pivot. I would think this isn't the way it is supposed to be.
I'm sure you have already figured out I have not had any experience with any plows and neither did the fellow I bought this plow from so he's no help!
Post a Followup
: Re: IH 2 disk breaking plow questions
