656 oil pressure
Posted by Brad on June 16, 2004 at 03:48:30 from (66.231.0.177):
I put an oil gauge on a 656 gas, the pressure is 37lbs at high idle. When at operating temp the pressure will drop to 20 lbs at idle, with 10-30
oil, is this aceptable? or is it time for bearings? thanks.
Post a Followup
: Re: 656 oil pressure
