Re: 656 oil pressure
Posted by Aces on June 16, 2004 at 12:59:01 from (67.0.38.13):
In Reply to: 656 oil pressure posted by Brad on June 16, 2004 at 03:48:30:
Brad.
I don't believe the store about the pump pumping so much, the same pump bearings as 460 560 gas desiel 706 gas 806 gas 756 gas 706 desiel. The problem with the spin on filter was the filter base just a wafer fiber valve that was no good, later IH came out with better but they should have left the gast iron base on never had trouble with them. The 706 G & D & 806 Gas had the gast iron the 656 first with spin on filter base, check it first. The valve could get off to one side and not hold pressure.
Post a Followup
: Re: Re: 656 oil pressure
