Re: Farmall A problems
Posted by Bob M on June 16, 2004 at 06:35:02 from (165.170.128.65):
In Reply to: Farmall A problems posted by Chad from MI on June 16, 2004 at 05:34:16:
Sounds like the mag has become sensitive to heat – not unusual as the mag gets old. Try filling a plastic bag with crushed ice and wrapping it around top and sides of the magneto (leave the distributor part of the mag sticking out). Secure the bag in place. Now run the tractor under load with the ice bag on on the mag. If it doesn’t quit, or if it runs longer before conking out the mag is the problem.
You could change the magneto – but a rebuilt is gonna run $150 - 200 or so. However it’s probably either the coil or condenser has become temperature sensitive - and you can change those out yourself. Figure about $60 for a new coil and condenser. Note: If you replace the coil and condenser it’s a good idea to replace the points too.
Good luck!
Post a Followup
: Re: Re: Farmall A problems
