Missing F-20 - - Wednesday update
Posted by Pete L on June 16, 2004 at 19:33:52 from (24.236.154.30):
Guys - Have done a lot of investigative work since my original message this past Friday. Lots of things checked, but to no avail. I need some information from you F-20 owners to hopefully find the "missing" issue on my tractor. 1) Can someone check their valve timing? Per the book, #1 cylinder should close its exhaust valve slightly before TDC, and open the intake valve just past TDC. Though this seems right, my tractor's valve cycles were running about 10 degrees late in the cycle. I adjusted the timing gears 3 teeth to get the cycle back to where the book said they should be. 2) Has anyone ever tested the vacuum on their intake manifold? I ended up drilling and tapping a hole (1/8" NPT) on the forward horizontal leg of the intake manifold and installing a vacuum gauge. Am only pulling 10-12" vacuum at no load speed. Seems low. Can you check yours? 3) During examination of the carburator innards, the die cast venturi has a couple flats cast into it on the outer flanges. It appears one is supposed to lock into a tab protruding from the main jet. Is it critical that this tab locate with the flats in the venturi, or anything else? 4) Some of you guys indicate frequently missing as "the nature of the beast" for F-20s when the spark is advanced and under no load. Are there some of you F-20 owners that have tractors that purr under any condition? 5) Last thing - - My tractor has an older aftermarket gasoline-only manifold with the letters HF122-L cast into it. Others of you have this manifold? Those of you with it, do your engines run smooth or miss when the spark is advanced under no load conditions? Thanx all. Will keep you posted with my findings. Pete
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
