Re: Farmall A problems
Posted by gene b on June 17, 2004 at 04:54:00 from (67.1.99.114):
In Reply to: Farmall A problems posted by Chad from MI on June 16, 2004 at 05:34:16:
The sound from the radiator is probably from crud in the block as there are a couple of holes below the sleeves where the water can flow thru for the system to work proper. You can add a water pump easy. The hit and miss is caused from the mag either condenser or the coil. There is no need to change the whole mag.
Post a Followup
: Re: Re: Farmall A problems
