Engine RPM too low
Posted by Andrew Kopel on June 17, 2004 at 05:59:46 from (12.2.73.20):
It’s me again. Thanks to everyone who helped me stopping the leak in my carb. Farmall 350 I now have the tractor running good at high idle, but the RPM’s are low (About 1100 when it should be 1925). I’ve fiddled with the carb adjustments and can’t seem to get it to speed up at all. Here is a background of what I did to the tractor when I replaced the carb that may have created this situation: 1) When I took off the gas tank I removed the engine speed control rod. I disconnected it in front of the gas tank. I do feel I put it back together correctly, but I did pull on the linkage quite a bit to get everything back together. 2) I had a difficult time getting the throttle plate back into the carb. It didn’t go in how I remembered it, but after I got it in the plate rotated freely in the passage. 3) I replaced the throttle plate shaft with a new one that came in the rebuild kit. 4) To idle adjustment needle is only 1/2 turn off of the seat and doesn’t seem to have any effect on the engine. If I have the needle out any further than 1/2 turn I can notice smoke coming out of the exhaust. 5) When I increase the engine speed it will over shoot 1100 RPM to about 1500RPM and then quickly slow down to 1100RPM again. What should my next step be? Put in the old throttle plate shaft, look at the valves, double check the timing, re-adjust the governor? I did remove the sleeve between the governor and carb and checked for any build-up. It was clean and the shaft seemed to rotate freely in it. Sorry for the long post, thanks in advance Andy
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
