Re: noisy 1066
Posted by Old Dutch on June 17, 2004 at 14:34:05 from (66.168.17.34):
In Reply to: noisy 1066 posted by Dan on June 16, 2004 at 07:57:41:
Dan: First thing is=did he replace the front oil pump and seal. The 'o' rings can and often do fall from the groove in the pump housing and front timing cover grooves. That aside, the next place is the filters, do they have a check valve built into the base to keep the oil from draining upon shutdown? If not you have to fill two filters before supplying oil to the bearings. Believe me I worked on many of those engines and I will not kid you. That takes awhile to supply everything with oil. The other thing to ask whom ever did the overhaul, is did they replace the cam bearings as that would and could be the biggest problem you are having. I would myself use an external oil pressure gauge at the pressure sender fitting, and get a reading first hand at startup. See if it is coming up right away. Sorry I can't help more but their are many things to be considered. If you need more help please post again.
Home
| Forums
Today's Featured Article -
Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
Latest Ad:
1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
