Re: Can a farmall H run a thrasher? and question a
Posted by John_N on June 18, 2004 at 10:02:08 from (24.117.100.204):
In Reply to: Can a farmall H run a thrasher? and question about posted by RedandGreen on June 17, 2004 at 22:32:09:
Here are the specs:
For an IHC 22x38 with a hand feed and folding stacker: 16 hp.
With a wind stacker, self feeder, and weigher, it says "McCormick-Deering 10-20", which was 21.6 belt hp.
On the 28x46, those went up to 22 HP and "McCormick-Deering 15-30", which is 32.86 BHP.
The cylinder RPM depends on the belt speed of the tractor and on the diameter of the pulley on the tractor. Which one you need for a thresher varied with the crop; both those threshers had an 8 1/2" face main drive pulley; available in 7, 8, 10, 11, 12, 14, and 15 inch diameters. You selected the proper drive pulley based on the tractor; of course different sizes were available there as well. Your IHC dealer could no doubt assist you in making the proper selection for your crop and tractor; that expertise is now hard to locate.
Tractors had different belt speeds. Here is a selection available to me right now, and the column format will probably be mangled:
tractor BFM pulley RPM
W-12 BFM: 2730 RPM: 787
10-20 BFM: 2575 RPM: 645
W-30 BFM: 2695 RPM: 675
W-40 BFM: 2627 RPM: 599
WD-40 BFM: 2580 RPM: 588
Super A BFM: 2574 (8 1/2") RPM: 1157
F-300 BFM: 2759 (9 3/4") RPM: 1081 (max @ full load)
The HP requirements for a thresher are quite modest; since they were stationery, you don't have a loss for moving anything. The capacity was likewise low, compared to more modern machines. It was a slower-paced time.
You could run a 20" thresher with a Super-A; an H would be easy. Getting the thresher tuned to work right is a skill. Hopefully, someone who knows how can help you learn.
Post a Followup
: Re: Re: Can a farmall H run a thrasher? and question a
