Re: valve stem guides on 460
Posted by El Toro on June 18, 2004 at 10:51:13 from (205.188.117.22):
In Reply to: valve stem guides on 460 posted by TimS on June 17, 2004 at 18:11:25:
Hi Tim, I had the same problem with an engine with
a lot of blowby. I pulled the head and found deep
grooves on one cylinder wall. This engine didn't
have slleves had to pull engine and get it rebored. Found a piston ring had broken and that scored the cylinder. These two guys gave you sound advice to take the head to a good machine shop and the crankshaft too, if it needs it. Hal
Post a Followup
: Re: Re: valve stem guides on 460
