Re: Broken H governor spring, bodge ?
Posted by Will Sick on June 18, 2004 at 22:28:08 from (199.120.121.95):
In Reply to: Broken H governor spring, bodge ? posted by riverbend on June 18, 2004 at 20:48:27:
The tension has to be right. Th spring increases the rpm when you pull the throttle and the weights decrease the rpm. The two have to be in tune. You might luck out and get a different spring that would get you going at least temporarily. I usually keep an extra on hand.
Post a Followup
: Re: Re: Broken H governor spring, bodge ?
