Re: C front wheel bearings
Posted by Haas on June 19, 2004 at 04:29:53 from (12.65.72.51):
In Reply to: C front wheel bearings posted by DANWV on June 18, 2004 at 12:44:26:
I agree with CNKS. You should not have to pull the dust shield up by tightening the spindle nut. The dust shield presses on before you put on the grease seal. There is also a "wear ring" that goes inside the hub, but as I recall, it only runs against the grease seal and is pressed in the hub before you apply the bearings. The spindle nut is only to tighten the bearings. That is the inner bearing race is pressed against a shoulder on the spindle and the outer race (IH parts calls it a cup) against a shoulder or lip in the hub. You should just tighten the spindle nut until the wheel has some resistance to turning and the then back the nut off to line the hole so you can get the cotter pin in the castle nut.
Post a Followup
: Re: Re: C front wheel bearings
