Re: 4 postion switch on Cub
Posted by ken gray on June 20, 2004 at 12:57:26 from (24.218.219.128):
In Reply to: 4 postion switch on Cub posted by Ken Gray on June 19, 2004 at 03:28:09:
Red, Here's the deal I did as you said. The volt meter read 6 without the battery connected (just charged it) starts right up. With the throttle at up about half the amperes Gauge (on the cub) registers about 6 amp on the Positive side (right of center). This is with the switch on "L". When I put the voltmeter on the battery there is a negative reading of -.24 when I switch to "H" "D" or "B" it reads 0.00 and there is a noticable change in the idle (better) With the switch on "H" the Gauge(on the cub) reads zero or maybe even a slight discharge. Turn to "D" or "B" and the results are the same , near zero reading.
I tried getting a reading with the voltmeter by placing the positive lead from the voltmeter to the cranking motor stud and the negative lead to the block and it gave me garbage. I pulled the cable off the battery and the tractor ran fine (it has a magneto). Checked the battery with the voltmeter, dead 0.00 reading. The positive lead from the battery is grounded directly to the side of the battery box (I didn't put the top on but that wouldn't make any difference would it?). The negative lead goes directly to the cranking motor. I checked the generator belt and it did seem a little loose but I doubt enough to effect it.
So Red, What do you think my next steps should be? new voltage regulator? Generator? or a freakin' hand crank? Thanks again for your help...
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
