Re: Re: Re: farmall super c oil pressure
Posted by Owen on June 20, 2004 at 17:14:39 from (149.174.164.83):
In Reply to: Re: Re: farmall super c oil pressure posted by john in ohio on June 14, 2004 at 17:51:02:
I have repaired many oil pumps like the Super C
use by sanding the bottom plate flat and then
reshimming with the correct gasket thickness. I
also add a steel bar accross the plate where it
had warped. I start with a piece about 1/2 x 1/4
the proper length and drill hole to match those on
the pump. A little grinding is necessary to firt
the plate. Assemble with longer bolts. I have
never had a failure on a pump with this added
Post a Followup
: Re: Re: Re: Re: farmall super c oil pressure
