Re: 706 conversion
Posted by Aces on June 22, 2004 at 08:13:36 from (67.0.38.13):
In Reply to: 706 conversion posted by matt on June 22, 2004 at 07:35:14:
Matt if you have an ealy 706 then the D282 will fit ok if you want the D310 the side rails need to be longer or if you have a late 706 then the side rails would fit the D310 or you could use a D358 in the late 706.
Post a Followup
: Re: Re: 706 conversion
