Re: Bad looking tranny oil
Posted by Darren in TN on June 22, 2004 at 18:02:54 from (68.19.200.181):
In Reply to: Bad looking tranny oil posted by farmallman on June 22, 2004 at 16:46:08:
Hey Farmallman,
I'm embarassed to read the kind of crappy answer you got first-- I hope it's not your first experience on these forums as most folks are pretty nice and decent enough to answer your questions courteously rather than blather on and insult you like that other fellow did.
To answer your question, it does sound like your tranny oil is contaminated with water, rust, etc. If your tractor is uncovered out in the elements it's likely that some rainwater entered by way of the shifter. Even if it is under cover, condensation can collect inside it and corrupt your oil. I believe your fill plug will be on top of the tranny casting in front of your seat and just behind the shifter (I may be wrong.) Your drain plug ought to be in the back near the PTO/belt pulley and at about the lowest point possible in the tranny housing. A guy named Rudi has a great site with manuals for the Cub and its implements online at the following URL:
http://www.cleancomputes.com/Cub/
He's a real nice and helpful fellow-- you'll see him post here on Cub matters from time to time.
I hope this info helps. Bst of luck wit hyour tractor,
Darren
Post a Followup
: Re: Re: Bad looking tranny oil
