Re: Some basic SMTA questions
Posted by Dan on June 22, 2004 at 22:35:13 from (12.160.171.192):
In Reply to: Some basic SMTA questions posted by Glen on June 22, 2004 at 21:23:10:
1. If original will be 6 volt positive ground. Should have a generator, if has an alternator is probably converted to 12 volt negative ground. 2.Should be pull rod to engage starter, switch is mounted to top of the starter. 3. Voltage regulator is mounted on the steering post near the bottom, engine side. 4. Could be TA problem. Usually TA fails such taht foreward speed is ok, will slip when pulled to rear. Try pulling handle back and then hitting brakes. Could also be adjustment. Adjustment procedure is complicated as it involves clutch linkage also. You need to have an operator's manuel to do it right. When I got my SMTA it had a worn out after market seat. I bought the seat with mount and battry box that was sort of decent from a salvage yard. Late super M and some number series had same seat and battery box. I would get new cables from battery to starter. If it is 6 volt use heavy cables. I ran mine across the floor board in flexible conduit to avoid damage from feet etc.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
