Re: 656d questions
Posted by Dan on June 24, 2004 at 07:19:30 from (12.160.171.192):
In Reply to: 656d questions posted by farmallwayne on June 24, 2004 at 05:12:55:
Haven't owned one but have worked with one quite a bit. Neighbor has a Utility model I used with a 9' Heston haybine last weekend,handles it with no problem. Plus is it seems to run very economically on diesel. Downside is it uses glow plugs to start. In 90 degree weather if you stop it for 15 minutes you have to use the glow plugs to start. In cold weather you use up all your battery heating the glow plugs and have little left to run starter. That seems to be a common story with others that have or have had one. I like the tractor. If it can survive with what little maintanance my neighbor does on his it must be tough.
Post a Followup
: Re: Re: 656d questions
