Re: GOVERNOR FOR 50 M
Posted by Jon on June 24, 2004 at 18:02:04 from (64.12.117.22):
In Reply to: GOVERNOR FOR 50 M posted by BUBSDAD on June 24, 2004 at 16:57:18:
Is your carb adjusted right? Next I would check the linkage that hooks to the carb . Make sure its seated in the right postion in the carb . Lossen the two screws that hold it on the carb and wiggle and turn it and see if that makes a different.I guess next would be to pull the cover off the GOV . Check holes for wear like where spring hooks,Spring ,Govener Adjustments, JON
Post a Followup
: Re: Re: GOVERNOR FOR 50 M
