Re: Re: Re: ORIGINAL SUPER MDTA ON EBAY
Posted by CNKS on June 24, 2004 at 19:04:58 from (207.178.96.212):
In Reply to: Re: Re: ORIGINAL SUPER MDTA ON EBAY posted by MM on June 24, 2004 at 03:24:10:
Problem is it is called a SMDTA, there are many features that indicate it is some sort of a hybrid: lights are the old style teardrop and the rod going to the hydraulics, including the bracket it is mounted in is from an MD, apparently the tractor has a belly pump, the Stage 2 Super M/MTA had live hydraulics. I live in Kansas, VT is a little too far to go to look at a misreprented tractor. If the tractor is not yours, you should contact the owner, clear it up, and give more detailed info as to exactly what the thing is. In this case the serial number really does not mean anything, you need to look at casting numbers on the various parts to see what has been changed.
Post a Followup
: Re: Re: Re: Re: ORIGINAL SUPER MDTA ON EBAY
