Re: Re: Gear/clutch plate problem
Posted by Phil on June 26, 2004 at 19:22:07 from (66.26.240.214):
In Reply to: Re: Gear/clutch plate problem posted by Matt on June 25, 2004 at 18:50:16:
thank you
Post a Followup
: Re: Re: Re: Gear/clutch plate problem
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
