Farmall Tractors Discussion Board
Re: 300 Utility questions - 3 point conversion - traction weight ???
Posted by john d on October 31, 1999 at 17:47:14 from (206.141.74.34):
In Reply to: 300 Utility questions - 3 point conversion - traction weight ??? posted by North Dakota Wayne on October 31, 1999 at 06:37:51:
The 300 Utility is a TOUGH little tractor. We used to have one, and the worst feature of ours was no power steering. Loader work with it was a chore!
As mentioned in another post below, 3pt hitches are available. If you have a 3pt, consider putting a blade on the back. Not only will that add weight where you need it most, but allow you to clean up what the loader doesn't move easily.
I've had some experience with one of these tractors in snow.... and you are DEFINITELY gonna need weight on the back end! I'm also wondering if you may have over-built that loader to a size that will make the rear of your tractor VERY light whenever you try to lift a big chunk of snow. I hope your snow up there is a lot drier than what we usually get in Indiana!
Chains will help a lot, but if you plant that loader in a big pile of snow and then lift it, the back of the tractor is going to be very light. Ours had a standard drawbar, and I used to put on an extension, then stack wheelweights from an M on top of the drawbar and bolt them in place to the extension. I've also put on some 3' lengths of RR iron at times.
Sooner or later you're going to get the urge to put that tractor in 4th gear, get it moving at top speed, and slam into a drift to break through. That will work better than you might think, but it may also result in landing your tractor up on a pile of snow. There isn't a lot of clearance under these, so you can get it stuck pretty easily. Pack a shovel. Lots of luck, and let us know how it works!!
Post a Followup
: Re: Re: 300 Utility questions - 3 point conversion - traction weight ???
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
