Re: Re: Re: Re: Re: Fire Crater Pistons
Posted by Shaggy on June 29, 2004 at 11:33:18 from (12.215.127.224):
In Reply to: Re: Re: Re: Re: Fire Crater Pistons posted by Ramon from NC on June 29, 2004 at 06:22:18:
Well from what I have learned from the people on here on from my own tinkering is this. A lot depends on the the size of the hole in the bottom of the block where the sleeve slips into and seals with a O-ring. Almost all B's and A's have a 3 5/16th hole and some of the early super A's. And that allows you to go to a 3 1/8 bore sleeve. But on the some of the later Super A's C's and 100 thru 140 etc. had a 3 7/16th hole in the block that would allow you to go to a 3 1/4 bore. I personally have never seen or used a 3 3/16 bore. Maybe someone else here has. Hope I helped a little. Shaggy
Post a Followup
: Re: Re: Re: Re: Re: Re: Fire Crater Pistons
