Re: MW live pump
Posted by CNKS on June 30, 2004 at 18:28:07 from (207.178.96.211):
In Reply to: MW live pump posted by Randy SE-MN on June 30, 2004 at 06:18:17:
Most likely all you need is the seal at the front of the pump. Pump is easy to remove, seal is easy to replace, if the shaft is worn, you may need a speedy sleeve. $5-10 seal, $20-25 sleeve should do it.
Post a Followup
: Re: Re: MW live pump
