Re: Diagnosing stuck distributor advance on '47 H
Posted by Answer for Bob - Dave in on July 04, 2004 at 19:35:25 from (64.252.221.99):
In Reply to: Diagnosing stuck distributor advance on '47 H posted by Dave in CT on July 04, 2004 at 09:52:28:
Thanks for the reply. I'm answering here because that image takes a while to load. I believe it's an IH distributor. So far my assembly is the same as your exploded view - with the exception of the washers or 'weight arm spacer's mentioned above. That exploded view is the same as my I&T exploded view. The numbers on the distributor are:
One side of body: 52
Other side of body: 353898R1
Side of flange where the distributor clamps clamp: HC5-757925
I'm used to a distributor where the plate revolves to advance with the greater RPM. I'm not getting the advance at the higher RPM (shown via the strobe timing light) but I'm not seeing how the weights are supposed to cause this advance.
Post a Followup
: Re: Re: Diagnosing stuck distributor advance on '47 H
