Re: Re: Distributor advance - '47 H
Posted by Dave in CT on July 05, 2004 at 20:27:14 from (64.252.222.169):
In Reply to: Re: Distributor advance - '47 H posted by Dave W V on July 05, 2004 at 11:49:01:
I think you're getting the closest to solving my problem. The hole in the plate allows for so little movement, 2.5 degrees sounds right (I was just guessing with my estimate). The distributor shaft plate (the plate just under the cam) has '8R' stamped into it and that's all.
The guy I bought the tractor from is local, deals in enough Hs he might be willing to correct this, even if the sale is a year old. I'd just like to get this engine running to specs.
I'll see what Wayne Swenson has on the issue and make sure to post what I find to be the solution. Thanks for your help.
Post a Followup
: Re: Re: Re: Distributor advance - '47 H
