Farmall Tractors Discussion Board
Re: Question on 12 volt conversion
Posted by Bob M on November 01, 1999 at 16:52:15 from (171.217.194.155):
In Reply to: Question on 12 volt conversion posted by David Page on November 01, 1999 at 11:33:33:
David - If your tractor's got a mag, you won't need the ignition resistor. You will however need a means to tell the alternator the engine is running. Can be a 2nd ignition switch, a new 2 pole ignition switch, or a normally open oil pressure switch wired into the warning lamp circuit.
Post a Followup
: Re: Re: Question on 12 volt conversion
