Re: what problems have you had with a 450
Posted by Carp on July 08, 2004 at 09:41:40 from (12.27.55.243):
In Reply to: what problems have you had with a 450 posted by RedandGreen on July 07, 2004 at 12:05:41:
There is an issue with the timing gear coming loose from the cam shaft. New cam shafts have LH threads and are less prone to loosening up. The priority valve for the power steering is another common area for a problem. I have not really heard of to many tranny problems, but I am sure it was an issue as when they went to the 560 all heck broke loose. And they do like gasoline, but they will pull like an ox.
Post a Followup
: Re: Re: what problems have you had with a 450
