what problems have you had with a 450
Posted by RedandGreen on July 07, 2004 at 12:05:41 from (4.249.231.118):
I have herd that when the 450 came out that the many had problems with the engine and transmission, What problems did you experance with this tractor? also did the timing gears wear out from driving the hydrolic (spelling) pump on the timing gear?
Post a Followup
: Re: what problems have you had with a 450
