Re: Farmall H again again(long post, im desperate)
Posted by captaink on July 09, 2004 at 09:06:46 from (66.115.212.249):
In Reply to: Farmall H again again(long post, im desperate) posted by Farm w/Junk on July 09, 2004 at 08:23:55:
Is there any chance you could have a carburetor full of water? Drain the carburetor, empty the sediment bowl under the tank and then try to start it. The bottom needle is the high speed fuel mixture screw. Try setting both mixture screws on the carburetor about one and one-half turns out from the fully seated position. This should be a good starting point and the engine should start and run. When it is running and warm you can fine-tune these adjustments. Does it drip continuously or just a little while after you have tried to start it? I have had it happen when I have tried to start an engine and choked it (and it failed to start) that gas dripped from the bottom of the carburetor for a little bit. If it is dripping continuously, it could be coming from a float setting that is too high, foreign material in the needle and seat preventing sealing or gas in the float from a leak causing it to settle in the bowl opening the needle and seat. Since it is popping when you choke it, this would indicate that it needs more fuel to start, meaning the carburetor is set too lean. This should help. If not, post back.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
