Re: Farmall H again again(long post, im desperate)
Posted by john d on July 10, 2004 at 06:10:12 from (205.188.117.22):
In Reply to: Farmall H again again(long post, im desperate) posted by Farm w/Junk on July 09, 2004 at 08:23:55:
Check the basics before tearing that thing apart. (If you haven't already!)
The engine needs 4 things, spark, fuel, and compression, and timing. If it ran earlier, and the bolts on the distributor are tight, timing is not likely to be the problem. If it ran earlier, sudden loss of compression is not likely the problem, either.
Check to see if you have a good hot (blue, not red) spark at each plug. If not, dig into the distributor and find out why. (Condenser, points, rotor, cap, wires, connections, etc.)
Make sure gas is getting TO the carb BEFORE you start taking it apart! Loosen the fuel line at the carb and see if fuel runs out. If not, then you're either out of fuel (Don't laugh, it's happened to lots of folks who wont admit it!) or something is plugged shut. If you have fuel, but no fuel flow, check the valve under the tank and the sediment bowl and screen under the tank. If the tank has rust or debris in it, you may have to remove the valve assembly to get it un-plugged.
If you have fuel flow, drain the carb, re-set the screws to specs, and give it a try. If that doesn't do it, you may have to yank the carb and open it.
Post a Followup
: Re: Re: Farmall H again again(long post, im desperate)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
