Cmore recycling hydraulic oil..how to fix
Posted by Cmore on July 10, 2004 at 17:17:03 from (66.226.101.159):
Cmore's fast hitch wouldn't raise so filled up with 20w non-detergent. Then discovered this afternoon that Cmore was low on hydraulic oil again...because it's going into crankcase!! Drained probably quart to quart and one half off out of top petcock on pan. How hard to fix? Do I remove the hydraulic pump and install new gasket?? Is this difficult?? Thanks for any and all advice..Cmore
Post a Followup
: Re: Cmore recycling hydraulic oil..how to fix
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
