Re: Changing Fast Hitch to Industrial
Posted by CNKS on July 10, 2004 at 18:18:25 from (207.178.96.211):
In Reply to: Changing Fast Hitch to Industrial posted by Jerry in WA on July 10, 2004 at 12:41:19:
3-point equipment for the size tractor you have is either category 1 or 2, 2 is wider than 1. Fast hitch came in a couple of different widths too, I don't know if it exactly matches the 3-point widths. With either system, you need to either attach the two lower 3-point links at the correct width, or weld the fast hitch prongs at the correct width to your equipment. This should work unless you are sharing equipment with someone. Unless your fast hitch is worn out, I wouldn't put an aftermarket 3-point on it, or as Hugh says, replacing the lower fast hitch arms with 3 point arms is probably too complicated. I would change the equipment to fit.
Post a Followup
: Re: Re: Changing Fast Hitch to Industrial
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
