Re: Re: Re: Re: Re: Changing Fast Hitch to Industr
Posted by CNKS on July 10, 2004 at 19:44:32 from (207.178.96.212):
In Reply to: Re: Re: Re: Re: Changing Fast Hitch to Industrial posted by Jerry in WA on July 10, 2004 at 19:07:16:
The hitch in the picture looks too wide for a Cat 1, but I really can't tell. Some one could have had it made to fit the implements he had, I don't believe that it is factory, perhaps Hugh can tell. Another thing that works sometimes (if the lower pins on the implement are bolted on), is to turn them around so that they point in rather than out. They might not be exactly the right spacing, but they might work. It appears that you have "quick hitch" arms bolted into the fast hitch sockets, as opposed to a three point conversion that you can just pull out?
Post a Followup
: Re: Re: Re: Re: Re: Re: Changing Fast Hitch to Industr
