Re: Timing Teeth in Pan (1256)
Posted by RPM on July 12, 2004 at 06:12:18 from (69.66.29.36):
In Reply to: Timing Teeth in Pan (1256) posted by Dan on July 10, 2004 at 05:32:34:
Be carefull, this engine probably has a worn front crank pulley, this is a quirk of this engine after years and many hours, the rubber looses its ability to dampen the shock load, it will break teeth off timing gears, break cam or crank snout. Only safe fix is NEW pulley, gears & other parts could be used.
Post a Followup
: Re: Re: Timing Teeth in Pan (1256)
