Re: Re: Stuck clutch, Cub
Posted by gene on July 12, 2004 at 11:52:56 from (208.144.172.132):
In Reply to: Re: Stuck clutch, Cub posted by lee on July 12, 2004 at 10:27:46:
There is a little access to the bottom of the pressure plate. I have loosened the bolts holding the pressure plate and used a gasket scraper to "loosen" the sides of the pressure plate. The heavy center portion of the pressure plate appears to be stuck to the disc.
There is a bolt hole on the side of the bell housing with not quite direct access to the side (heavy center portion) of the pressure plate. I may be able to get a wedge in there. I was trying this earlier today in the rain. Quit when the water kept dripping in one eye.
The tractor is currently sitting in my driveway, in town. If I can't get it free here I will trailer it to our acreage. There I will try driving the tractor, locking the brakes with the clutch depressed. My shop is on the acreage.
Thanks.
Still more ideas wanted.
Post a Followup
: Re: Re: Re: Stuck clutch, Cub
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
