Re: stuck m
Posted by John A. on July 12, 2004 at 19:32:04 from (65.161.170.17):
In Reply to: stuck m posted by chris on July 12, 2004 at 16:25:07:
chris, Since you have the head off, and pan off too. Remove the rod caps, One at a time fill a cylinder with diesel about 1/3 full, set it on fire, let it burn itself out, it should free up and you are well on your way. The heat at the ring area is what breaks it loose after it moves a little soak it good with penetrating oil.
Precausions and prep are allways needed make sure ALL flammable materials are well away from the tractor, Gas tank is off and away too. Also roll tractor outside if possible.
Hope this helps!
Later,
John A.
Post a Followup
: Re: Re: stuck m
